Пара вопросов по серверам
Форум: Серверы (http://forum.ixbt.com/?id=66)
URL: http://forum.ixbt.com/topic.cgi?id=66:7462
Дмитрий Мартынов, 15.10.2009 16:47
Добрый день!
Есть два серверам (supermicro)
На первом в логе ошибки и вчера сервер опознавал присутствие контроллера один раз из трех-пяти при перезагрузке
Event Type:Warning
Event Source: arcsas Event Category: None Event ID: 129 Description:
The description for Event ID ( 129 ) in Source ( arcsas ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: \Device\RaidPort0.
Event Type: Error Event Source: atapi Event Category: NoneEvent ID: 9 Description: The device, \Device\Ide\IdePort0, did not respond within the timeout period. Event Type: Error Event Source: atapi Event Category: None Event ID: 11 Description:
The driver detected a controller error on \Device\Ide\IdePort0 Event Type: Error Event Source: Disk Event Category: None Event ID: 11 Description: The driver detected a controller error on \Device\Harddisk2 Event Type: Warning Event Source: Disk
Event Category: None Event ID: 51 Description: An error was detected on device \Device\Harddisk2 during a paging operation
Event Type: Warning Event Source: Fastfat Event Category: None Event ID: 50 Description:
{Delayed Write Failed} Windows was unable to save all the data for the file . The data has been lost. This error may be caused by a failure of your computer hardware or network connection. Please try to save this file elsewhere
На втором сервере тестирование отдельных планок проходит - testmem 3.5 x86, если вставляешь все 4, перезагрузка на тесте номер 1 на 45-47% при тестировании области 0 -2048 Мб
Что бы это могло значить? Спасибо
1. a_shats, 15.10.2009 17:13
Дмитрий Мартынов
А гарантия что говорит ? Особенно насчет планок.
2. Дмитрий Мартынов, 15.10.2009 21:52
a_shats
по первому - вычислили диск с бедами, воткнули нормальный. говорят возможно из-за него. во второму - сказали тестировать планки попарно
Добавление от 16.10.2009 12:08:
Коллеги, у меня собственно вопрос по Adaptec 5805 в первом сервере - если я обновлю прошивку в контроллере и рейд не увидит метаданных на дисках, прошивку я залью обратно предыдущую версию. А если я обновлю драйвер Windows на последний и данные окажутся недоступны, как его обратно вернуть? ОС же c того же рейда грузится. Шаманить в Recovery Console?
3. Лёлик, 16.10.2009 13:50
сними образ системы acronisом или ghost. Перестраховка никогда не помешает. Если получишь синий экран после смены драйвера можно залить образ, заодно произойдет полная дефрагментация диска (при заливке образа).
4. gss, 16.10.2009 13:53
Дмитрий Мартынов
С чего это вдруг?
5. Дмитрий Мартынов, 16.10.2009 14:26
Лёлик
чем докажешь?
gss
разве обновление драйвера контроллера никак не может повлиять на доступность данных? В 100 случаях из 100 все пройдет нормально?
6. gss, 16.10.2009 14:57
Дмитрий Мартынов
В 99% случаев все будет нормально, если соблюдать обычные правила.
А если вдруг что-то не так, то должен быть бэкап.
7. Лёлик, 16.10.2009 15:11
Дмитрий Мартынов
ghostом сам пробовал. Самый быстрый способ дефрагментации. Снял с диска c: образ, потом сразу же развернул, дефрагментация 100%. Acronisom не пробовал. Единственное лучше так не делать на DC.
8. gss, 16.10.2009 15:14
Backup Exec System Recovery
9. Дмитрий Мартынов, 16.10.2009 15:35
ок, значит образ системного раздела и вперед. Спасибо!
10. Дмитрий Мартынов, 17.10.2009 18:19
Лёлик
кстати насчет полной дефрагментации после заливки образа, вспомнилось. тут была большааая ветка с итоговым выводом о практической бесполезности дефрагментации данных на raid
