Dual layer burning!
URL: http://forum.ixbt.com/topic.cgi?id=31:18374
dimitre, 07.12.2003 01:56
Dual layer burning firmware for BenQ DW800A in Jan 2004? *updated*
http://www.cdfreaks.com/news/8616
что за драйв такой? есть ли у кого? или это способ улучшить продажи
1. Denis Kalishevich, 07.12.2003 13:26
А болванки то где брать такие? ИМХО, пока Филипс оффициально не выпустит DVD+R9, в массы это не пойдет. А привод наверное самый обычный, просто дуальная фича включаеся методом апгрейда прошивки.
2. 909, 20.02.2004 09:22
www.cdrlabs.com
DigiTimes has reported that both Philips and MediaTek expect to offer a dual-layer DVD+R solution during the second quarter of this year.
Philips expects to begin offering downloadable firmware that supports dual-layer DVD+R technology to system makers in the second quarter, said Marconi Jiang, general manager of sales at Philips Semiconductors in Taiwan.
System makers can download the firmware to upgrade existing DVD+RW chips from supporting 4.7GB to 8.5GB. Taiwan driver vendors including BenQ have already committed to the technology for 8x DVD systems, said Jiang.
Philips dubs the dual-layer DVD+R technology DVD+RW 9. The technology is said to double the data storage capacity on DVD recordable discs from 4.7GB to 8.5GB and remains compatible with existing DVD video players and DVD drives, according to an October 3 press statement from Philips.
MediaTek is offering a new chip supporting dual-layer DVD+R to its system customers. Lite-On IT expects to begin mass production of recorders that support the technology in the second quarter, according to sources. MediaTek does not expect any intellectual property problems, according to Ming-kai Tsai, chairman of MediaTek.
I don't want to speculate, but this article makes it sound like BenQ and others will be able to add support for dual-layer to their 8x DVD writers. The big question will be whether or not they'll offer this upgrade to existing customers. If you want to read more, the entire article is available at DigiTimes.
3. 909, 01.05.2004 14:25
Первые тесты DL-записи
http://www.cdrinfo.com/forum/tm.asp?m=65987
http://www.cdrinfo.com/forum/tm.asp?m=65991
Вобщем, пока в стандарт не укладываемся ... совсем
4. Myuni Hausen, 02.05.2004 08:06
Да, графики второго слоя немножко страшненькие. С другой стороны, уже сегодня прогрессивный Китай может предложить, например, однослойные SKY, легко побивающие все мыслимые рекорды по числу ошибок.
Через год, думаю, появятся приводы/болванки, которые будет смысл покупать.
5. 909, 07.05.2004 11:20
www.cdrinfo.com
Посмотрел обзор Dual Layer DVDRW. Судя по картинке, описывающей структуру DL-диска первый слой - L0 находится ближе к оптической головке, чем второй - L1. Если запись начинается со слоя L0, тогда запись на второй будет сопряжена с дополнительнительными трудностями - предыдущая поверхность уже "продырявлена" записью - при прохождении луча через уже записаный слой могут возникнуть дополнительные помехи/искажения. Логичнее было бы начинать запись с дальнего от головы слоя ...
6. abgm, 07.05.2004 11:32
Так, чтобы одинаковые темы не плодить, перенесу
А вот и первая реальная новость с "двуслойного" фронта (продолжение)
to All & Гиперпотам
Статья на CDRLabs: Double Layer DVD+R Technology Preview (http://www.cdrlabs.com/articles/index.php?articleid=30)
В ней дается небольшой обзор самой двухслойной технологии и примеры записи DL DVD+R manufactured by Mitsubishi Chemical Corporation. Запись делалась на Sony DRU-700A (OEM Lite-ON SOHW-832S). Приведены тесты записанных дисков с пом. программы KProbe2.
http://www.cdrlabs.com/articles/images-view.php3?imageid=5799 (450x500, 50.1Kb)
И в продолжение темы, превью BenQ DW830A DL recorder (http://www.cdrinfo.com/Sections/Articles/Specific.asp?ArticleHeadline=BenQ+DW830A+DL+recorder&Series=0) на чипсете Philips.
О Боже! И CDFreaks туда же... A first look at dual layer DVD+R writing - Introduction and specifications (http://www.cdfreaks.com/article/142) , опять же про BenQ DW830A Dual Layer DVD-Writer.
Кстати, в последнем обзоре оччень интересный рез-т совместимости чтения DL DVD+R.
Drive/Firmware/Detects the disc/Reads the disc/Reading speed
Plextor PX-708A/ 1.06/ No/ No/ -
Lite-On SOHW-832S/ VSVD/ Yes/ Yes/ 2.5-6x CAV
BenQ DW830A/ A4B8/ Yes/ Yes/ 3.5-8x CAV
BenQ DW822A/ B3BC/ No/ No/ -
NU DDW082/ B373/ No/ No/ -
Pioneer DVR-106D/ 1.07/ No/ No/ -
Pioneer DVR-107D/ 1.13/ No/ No/ -
Lite-On LDW-811S/ HS0Q/ No/ No/ -
NEC ND-2500A/ 1.07/ No/ No/ -
BTC DRW1108IM/ 0218/ No/ No/ -
Asus DVD-E616 DVD-ROM/ 2.2/ Yes/ No/ 3.5-8x CAV*
JLMS XJ-HD165H DVD-ROM/ CH12/ Yes/ Yes/ 3.5-8x CAV
Lite-On SOHC-5232K Combo/ NK06/ Yes/ No/ 6-12x CAV*
Toshiba SD-M1612 DVD-ROM/ J806/ Yes/ No/ 6-16x CAV*
* - помечена скорость считывания 1-го слоя и ошибка при чтении 2-го
Добавление от 07.05.2004 11:36:
909
Думаю, при этом возникнет проблема совместимости. Вряд ли "читатель" сможет разобраться с DVD у которого записан только второй слой, например .
7. GeoN, 07.05.2004 11:55
Туда же: обзор double layer рекордера Sony DRU-700A на Anandtech.
http://www.anandtech.com/storage/showdoc.html?i=2045
Мда, история повторяется.
Вряд ли на стационарах будет лучше.
8. 909, 07.05.2004 13:12
abgm:
Очень сильная инфа!!!
Хотя возможно, что тестовые DL-диски записывались без bitsetting'а, а это, имхо, может поправить положение ...
9. GeoN, 07.05.2004 13:42
909
Да, на cdfreaks именно так и писали.
На cdrinfo результаты по совместимости очень близки к тому, что получилось у cdfreaks. Разве что на DVD-ROM'ах получше. С bitsetting там тоже не проверили.
http://www.cdrinfo.com/Sections/Articles/Specific.as…order&index=4
10. 909, 07.05.2004 14:10
Ясно.
Будем ждать продолжения с bitsetting'ом ...
В принципе возможен вариант, при котором при записи на один слой DL-болванки будет писаться на верхний слой, а при двухслойной записи - запись начнётся с нижнего. Данные можно в конце концов конвертнуть необходимым для стационаров образом. Хотя возмутся ли за это производители ...
11. abgm, 07.05.2004 14:34
909
Насколько я понимаю, bitsetting актуален для достаточно старых DVD-плееров. DVDRW - на это дело "начихать", т.к. они просто должны распознать болванку (ее тип) - и, кстати, есть большая надежда, что прошивками производители дело поправят и они хотя бы смогут DL-диски читать. А вот для комбо и DVD-ROM - гл. проблема именно в невозможности прочтения второго слоя. Это уже серьезнее. Видимо придется существенно улучшать качество дисков и качество записи. Боюсь, что та же проблема будет подстерегать и бытовые плееры (исключая, возможно, BBK ).
Добавление от 07.05.2004 15:16:
Варианты есть. Но, возможно, первый слой и несильно фокусировке-то мешает? По-этому и не стали заморачиваться? Причины могут быть и в другом...
Добавление от 07.05.2004 19:01:
BTW. Интересно, Lite-ON 812 легко перешивается в 832(DL). Появляется ли при этом возможность распознавать DL DVD+R?
12. Хитачик, 07.05.2004 20:59
Мдя.... почитал буржуйские обзоры... оптимизЬму пока мало. Не потому ли Pioneer не торопится с объявлением своих двуслойных продуктов?
13. 909, 07.05.2004 22:51
abgm:
Я имею ввиду стационары. С DVDRW имхо проще - вышла новая прошивка - появилась возможность читать. Со стационарами сложнее, но битсеттинг может помочь, имхо.
[q]
Вот и я об этом.
[q] А вот для комбо и DVD-ROM - гл. проблема именно в невозможности прочтения второго слоя. Это уже серьезнее. Видимо придется существенно улучшать качество дисков и качество записи. Боюсь, что та же проблема будет подстерегать и бытовые плееры (исключая, возможно, BBK ).
Короче говоря, имхо, стационарам может помочь в данном случае только битсеттинг, а для остальных (DVD-ROM,DVD-CDRW, DVDRW) должна помочь смена прошивки. Ведь штампованый "Dual Layer" читают все. Так что вероятность высока.
Конечно причена может быть в другом ( скорее даже наверняка в другом ).
Просто так бы было логичнее, имхо. И я, честно говоря, пока немогу понять логики уровня и расределения PI на втором слое.
14. Гиперпотам, 08.05.2004 14:28
Выходит, годик надо обождать. Технология явно сырая, и на первом поколении рекордеров и болванок её детские болезни преодолены не будут.
ИгорьТ
15. abgm, 08.05.2004 16:35
Гиперпотам
Сложно, конечно, прогнозировать. Но, надеюсь, раньше бОльшая работоспособность случится . Да и бОльших скоростей записи хочется увидеть.
16. abgm, 16.06.2004 08:58
to All
Про обзор LiteON SOHW-832S Dual DVD±RW Recorder (Double Layer): Пишущие DVD-дисководы от Lite-On: тесты, впечатления, мнения., #1045 (http://forum.ixbt.com/topic.cgi?id=31:17819:1045#1045)
17. Дем, 16.06.2004 12:41
909
ты не путай DVD-ROM DL и DVD+R DL - у них форматы сильно разные
Так что даже битсеттинг может не помочь...
А вот новая прошивка - очень даже может...
Тому пример "NEC ND-2500A/ 1.07/ No/ No/ -" - который после перешивки становится "NEC ND-2510A/ ???/ Yes/ Yes/ -"
18. 909, 16.06.2004 14:58
Дем
Я говорю о том, как стационарный плеер будел распознавать DVD+R DL, если он понятия не имеет о существовании этого формата. Распознав в таком диске DVD+R он просто не будет искать второй слой. Другое дело, если диск DVD+R DL представится, как DVD-ROM DL. Тогда, даже не имея понятия о дисках DVD+R DL и даже возможно о DVD+R он может попытаться прочитать оба слоя.
Жалко в обзоре 832-го на cdrinfo мало стационаров было
19. Дем, 17.06.2004 10:38
909
Ну это да... Хотя - какой на DVD+R DL слой "первый"? не внутренний, случайно?
20. 909, 17.06.2004 12:53
Дем
http://www.ixbt.com/optical/nec2510/dl-disk.gif
21. Anonymous, 24.06.2004 17:59
Что-то я не совсем понимаю, ёмкость 9.5Гб это только у штампованных двуслойных DVD? У "самописных" двуслойных DVD ёмкость только 8.5Гб?
22. bib, 24.06.2004 19:24
Anonymous
у штампованых двухслоек (не путать с двухсторонними) тоже 8.5Гига
23. DimmY 2000, 24.06.2004 20:22
Anonymous
bib
Хотя на самом деле все же не 8.5, а 7.92 Гбайт. Как, кстати, не 4.7 у однослойных дисков, а 4.38 Гбайт.
Но если у вас в гигабайте содержится миллиард байт, и вы чихать хотели на 1024 и прочие глупости, тогда, конечно, получится 8.5 Гбайт. Реклама, блин!
24. bib, 25.06.2004 10:02
DimmY 2000
7.95Гб, если уж совсем придираться (FAQ (http://dvdspecial.ru/dvdfaq3.phtml#3.3) ). Имею пиратку "Фанфан - Тюльпан" R5 емкостью 7.94Гб
25. Anonymous, 25.06.2004 16:22
Ясно. А всё-таки откуда взялась эта цифра 9.5ГБ?
26. Дем, 25.06.2004 17:22
Anonymous
Может от двухсторонних (4.7*2)?
27. 909, 28.06.2004 19:28
На cdrinfo потестили филипс 885
http://www.cdrinfo.com/Sections/Articles/Specific.as…es=0&index=18
Шо характерно все стационары филипс и пионер, даже старые, нормально играют DL, записаный с booktype!!!
Похоже, DL почти созрел ...
28. Anonymous, 28.06.2004 23:53
А будет ли двуслойный DVD+RW?
29. Antonio0, 08.07.2004 14:33
а вообще какие приводы счас умеют двухслойки писать и какие из них лучше это делают?
30. GeoN, 24.07.2004 13:32
Моя первая проба DL-записи.
Диск Verbatim DataLifePlus Double Layer DVD+R 2.4x 8.5Gb, Reorder 43459, "Зделано в Сингапуре".
Unique Disc Identifier : [DVD+R-DL:MKM-001-000]
Disc Type : [DVD+R DL]
Manufacturer ID : [MKM]
Manufacturer Name : [Mitsubishi Kagaku Media]
Media Type ID : [001]
Product Revision : [Not Specified]
Disc Application Code : [General Purpose]
Recording Speeds : [1x , 2.4x]
Blank Disc Capacity : [4,173,824 Sectors = 8,152.0MB = 7.96GB (8.55GB)]
Запись делал на NEC-2500. Прошивка 2.06 от NEC 2510 официальная. По информации на cdfreaks с этой прошивкой (так же как с 2.05) поддерживается auto-bitsetting для DVD+R9
http://club.cdfreaks.com/showthread.php?t=101340
Т.е. booktype для этих дисков по умолчанию устанавливается в значение DVD-ROM. Кроме того, обнаружилась bitsetting-утилита для NEC 2510 - WinBType, позволющая менять booktype опять же только для DVD+R9: http://club.cdfreaks.com/showthread.php?t=100576&page=2&pp=25
Работает вроде бы только на официальных прошивках NEC 2510.
На диск записан любительский фильм, объем 8,4х10^9 байт (7,85 Гб), формат DVD-Video, запись делал в Nero 6.3.1.17.
Фрагмент окна Nero во время записи:
314x205, 4.3Kb
Записанный диск в самом NEC определяется как DVD+R DL, но с booktype DVD-ROM:
417x174, 2.6Kb
В DVD-ROM дисководах диск определяется как DVD-ROM.
Сам NEC читает его небыстро (как и штампованные двуслойки), но гладко:
468x352, 8.2Kb
DVDRW Benq 822 диск не определил, для пишущих дисководов это нормально, большинство из них без обновления фирмвари DL-диски читать не будут, и booktype здесь не помогает.
DVD-ROM Sony DDU1621 прочел диск на полной (для DL) скорости 10x CAV без каких-либо сложностей:
466x354, 8.8Kb
К немалому моему удивлению диск прочелся на DVDRW Lite-On 401@411, и тоже совершенно гладко:
466x352, 8.7Kb
Благодаря этому удалось прогнать тесты в KProbe (использовал версию 2.2.3).
Были нюансы со скоростью чтения во время теста, установка скорости 4х с DL-диском давала режим чтения CAV, а не CLV как обычно. CLV работает только на скорости 2х. Поэтому сделал два скана - на максимальной скорости 8х, и на 2х CLV.
8х: http://geones.narod.ru/NEC2500/dl/dl_8x_scan.png
2х: http://geones.narod.ru/NEC2500/dl/dl_2x_scan.png
Диск нормально воспроизвелся на DVD-плеере Onkyo 501, определялся не дольше, чем обычные DVD+-R, переход на второй слой слой прошел гладко. Плеер Sony 305 диск определить не смог.
31. abgm, 24.07.2004 17:23
32. Eugene N., 24.07.2004 18:26
Все это интересно, только когда Пионер сподобится на привод (а потом хорошие люди сломают прошивки и для более старых приводов типа DVR-106D/107D )
33. DenKiller, 24.07.2004 20:46
А его уже можно купить
34. GeoN, 24.07.2004 22:02
Eugene N.
Уже сподобился на 108d. Только перепрошивке 106/107 это не поможет, чипсет другой.
DenKiller
Можно. Дорого.
Я подарю сделанный диск другу на день рождения (на диске много моментов, которые его порадуют ), и на какое-то время о DL забуду. Любопытство удовлетворено, а практический смысл пока отсутствует.
35. Андрейка, 24.07.2004 22:45
У меня прошивка 2k5107v2b5dl отсюда http://nuzhno.ru/files/2k5107v2b5dl.rar Пропатченная прошивка для NEC-2500, - regionfree, auto bitsetting, DL (Dual Layer) support, 8x на 4x дисках, а привод в нере определяется как 2500, а у тебя определяется как 2510 хотя ты пишешь что привод у тебя 2500... Это ты ошибся или твоя прошивка переименовывает привод.
36. Ночной_Дозор, 25.07.2004 04:14
Если будет возможность, попредлогай этот диск большему кругу стационарников. То, что Onkyo он понравился радует, от Sony никто вежливости и не ожидал. А как со вскими PAnasonic, Pioneer и т.п. Очень интересно.
37. Дем, 25.07.2004 06:29
Андрейка
Имя привода задаётся в прошивке, так что, если пропатчить соответствующе - можно хоть своё имя туда вбить а уж 2510 на 2500 поменять - раз плюнуть.
Другое дело - что виндозный прошивальщик это имя проверяет...
38. a-ha, 25.07.2004 06:42
Присоединяюсь к Ночной_Дозор. Особенно интересует, читает ли его BBK 965S?
39. skws, 25.07.2004 09:34
Андрейка:
Так он же пишет :"Запись делал на NEC-2500. Прошивка 2.06 от NEC 2510 официальная." А у тебя пропатченная от Herrie
40. Андрейка, 25.07.2004 12:13
А может кто нибудь сказать чем моя хуже... или в чем отличие этих двух прошивок??
И если не сложно дайте прямую ссылочку на эту официальную..
41. Кренг, 25.07.2004 13:43
http://tdb.rpc1.org/firmware/2510_206.ZIP
42. skws, 25.07.2004 13:47
Андрейка
Почему хуже-то? У меня тоже 2k5107v2b5 ,пока ничего предосудительного не заметил(тьфу,тьфу,тьфу) ,хотя некоторые товарисчи жаловались,что при записи 8-ми скор.DVD-R болванок были ошибки с bufer underrun protection. У тебя как машинка себя ведет?глюки какие-нибудь замечались? Хотелось бы тоже попробовать DL, однако таких болванок в нашем городке не замечено
43. Андрейка, 25.07.2004 14:42
По DL ничего не скажу, а по остальным CD,DVD вопросов нет, работает нормально. Правда сам я диски 4х не писал на скорости 8х но приятель писал и всё ОК, читается на ура, прошивка таже.
Проблемы были и на пишущем CD и на пишущем DVD тогда, когда они оба сидели на контроллере от ПРОМИСа, но когда я их воткнул в мать всё исчезло. У меня машина под видеомонтаж и на ней 3 харда и 3 сидюка, поэтому пришлось ставить дополнительно контроллер. Система МЕ это всё обслуживает.
Мне ещё интересно как будут писаться диски DVD+R, с каким значением, по умолчанию заявлено auto bitsetting, но сам ещё не писал. В основном пишу на минус.
44. skws, 25.07.2004 17:35
тут отзывы граждан о прошивке 2.06
45. Eugene N., 25.07.2004 17:46
Обидно, однако, иногда надо записать больше 4.38 гиг на один диск, особенно видео , а покупать новый привод как-то не хочется...
46. Андрейка, 25.07.2004 18:00
skws
А у кого с инглишем не очень можно в двух словах, аааааа....
47. GeoN, 25.07.2004 22:03
Андрейка
Ты невнимателен, я использовал оригинальную прошивку от 2510. В 2k5107v2b5dl name-string исправлена на 2500.
Использовал именно ее, потому, что в ней есть auto-bitsetting для двуслойников. Без смены booktype двуслойники пока имеют очень невысокую совместимость. 2k5107v2b5dl bitsetting поддерживает, но сделать это для DL пока нечем. В Nero функция bitsetting повилась, но как работает с DL непонятно, надежной информации я не нашел, и с единственным диском рисковать не стал.
Ночной_Дозор
Мне это и самому интересно, но диск у меня будет еще не так долго, вряд ли что-то успею попробовать.
48. Андрейка, 25.07.2004 23:52
Я скачал а там 3 прошивки. Какую из них нужно шить. Или чем они отличаются. С языком у меня не очень поэтому если не сложно то подскажи.
а в том что у меня прошито только для DVD+R или нет, и нужно ли её как то активировать???
И ещё вопрос по региону. Я пишу домашнее видео на DVD диски и некоторые спрашивают а будет ли этот диск читаться за границей??? Англия,Франция...
Если кто то может подсказать то заранее благодарен.
49. GeoN, 26.07.2004 00:41
Андрейка
Для начала реши нужно ли вообще и зачем.
чем они отличаются.
2510ORIG.BIN - оригинальная прошивка для 2510
2510FAST.BIN - то же со снятым ограничением на скорость рипа DVD-Video
2510RPC1.BIN - плюс к этому RPC1.
Прежде чем чего-либо "активизировать", разберись что это и зачем. И нужно ли тебе. И нужна ли тебе запись на двуслойники прямо сейчас.
В 2k5107v2b5dl установка booktype возможна с помощью DVDInfoPro для DVD+R/RW.
50. Андрейка, 26.07.2004 15:39
В общем конечно нет
Как я понял ДВД+ диски будут определяться как РОМ и скорость чтения будет выше и совместимость с бытовыми плеерами лучше... может я не прав, но я так понял. Конечно для меня это не главное но желательное, потому что занимаюсь перегоном домашнего видео на ДВД.
Я эту программу скачал но ничего не понял как и что.... одно слово пользователь!!!!
Для меня желательно чтоб диск читаться за границей??? Англия,Франция...
51. Igorok, 26.07.2004 16:08
Андрейка
В общем конечно нет
А ты часто меняешь писалки?
мне вот друг принес фирмовый блюнотовский диск с джазовым концертом, очень просил скопировать 1:1, а там 6 гиг в сумме, ну никак на обычную болванку не влезет, обсудили с ним проблему, будет ждать подешевения двухслойных болванок и наличия у меня двухслойной же писалки, пока держу образ, жесткий диск позволяет , ты уверен, что застрахован от подобной ситуации?
А качество записи и совместимость скоро у всех выправится, главное своевременно прошивки обновлять
неужели ты собираешься в ДВД с домашним видео вставлять зонную защиту?
если нет, то и проблемы нет
52. Андрейка, 26.07.2004 18:31
Igorok
Я не спец, и как я понял зонность идёт с прошивкой привода, может конечно я не прав. Поэтому и вопрос задал.
Среди знакомых есть заграничники и они мне задали этот вопрос а как ответить им я не знаю.
53. SergeyO, 26.07.2004 19:08
Андрейка
Зональность ставится при создании ДВД видео, но не при записи, т.е. если ты при создании своего видео не выбираешь никакой зоны, то записанный диск с этим видео идёт как ALL (все зоны) и смотреть его можно везде.
Диски с зонами рипают с опцией "Снятие зоны", т.е. становится ALL.
да, но влияет это только на просмотр ДВД видео (не на запись!).
54. GeoN, 26.07.2004 19:43
Андрейка
Все так.
Если ты хочешь, чтобы твои диски читались на самых разных DVD-плеерах, то установка booktype=DVD-ROM на DVD+R дисках очень полезна.
Запускаешь программу, находишь кнопку +RW, жмешь ее: http://www.dvdinfopro.com/images/screen.jpg
В появившемся окне выбираешь booktype DVD-ROM, и жмешь кнопку "Set Drive Default (DVD+R media)":
428x221, 27.1Kb
Закрываешь программу. С этого момента все +R диски будут писаться с booktype=DVD-ROM, дисковод "запомнит" какой booktype ставить. Nero использовать не ниже 6.3.1.6.
При желании всегда можешь вернуться назад.
А вообще все твои вопросы в этой теме - чистый оффтоп.
55. Андрейка, 26.07.2004 21:30
Ещё вопрос, а это заносится в привод?? или где то сидит в винде?? Это я к тому что если я делаю формат С:/ то нужно опять чтото делать????
Прошу прощения за может глупые вопросы.
56. GeoN, 27.07.2004 02:33
Андрейка
Прочти предыдущий пост внимательно.
57. bib, 27.07.2004 12:06
В последних Нерах же можно так же выбрать booktype при выборе резака.
58. GeoN, 27.07.2004 14:53
bib
Я знаю. Но у меня нет достоверной информации о том, работает ли это реально для DL-дисков с NEC 2500.
59. Андрейка, 27.07.2004 18:25
Сделал как написано. НЕРА 17, записал 2 диска и оба не ROM. Смотрел той же программой нажав на Медиа инфо.
60. GeoN, 27.07.2004 19:15
Андрейка
Разбирайся что не так сделал. С v2b5dl, DVDInfoPro и Nero 6.3.1.6 работает.
Всем твоим вопросам место здесь: Nec nd-2500a (http://forum.ixbt.com/topic.cgi?id=31:18421)
61. Igorok, 29.07.2004 14:58
Antonio0
тебе весь список?
набери в гугле DVD+R dual layer
пока все не супер хорошо, зреет технология
ждем-с...
62. Taurussian, 26.08.2004 14:19
Андрейка
Родные прошивки для 2510 позволяют менять BookType только для DVD+R9 (2-слойных). Возможно, ты изменил только BookType для DVD+R9?
Чтобы менять BookType для 1-слойных DVD+R(W), надо воспользоваться соответствующей прошивкой, насколько я знаю, пока это возможно только с прошивкой 2k5107v2b5dl (http://nuzhno.ru/files/2k5107v2b5dl.rar) , которая предназначена для ND-2500, но, по отзывам, работает и на 2510. Хотя сам я не пробовал её шить.
И ещё, некоторые пользователи сообщали, что после изменения BookType для +R(W) первый записанный диск всё равно имел BookType DVD+R, и только начиная со второго - DVD-ROM.
63. GeoN, 26.09.2004 11:19
DVD Forum одобрил спецификации Dual Layer DVD-R.
http://www.dvdforum.org/27scmtg-resolution.htm
64. abgm, 07.10.2004 06:30
Verbatim starts to ship 2.4 -5x DVD+R double layer 3-packs (http://www.cdfreaks.com/news/10638)
65. SpasitelofMoney, 08.10.2004 16:01
Народ а кто что думает(слышал) будут ли двухсторонние двухслойные
DVD+-R/RW диски?
66. abgm, 13.10.2004 07:28
8x DVD+R DL writers to be released in Q1 next year (http://www.cdfreaks.com/news/10680)
67. Хитачик, 14.10.2004 01:13
abgm ну и что? Уже давно можно купить Ritek DL (http://www.newegg.com/app/ViewProductDesc.asp?description=17-132-371&depa=0) по 5 штук... где три - там, как грится, и пять
68. Igor I, 14.10.2004 01:28
Хитачик
Похоже про 8х скорость у DL дисков ошиблись - там написано:
Specifications:
Speed: 2.4X
69. GeoN, 19.10.2004 00:28
Еще одна проба Dual Layer, на этот раз на Benq 822 с последней прошивкой (с поддержкой DL-записи).
Диск опять же Verbatim DataLifePlus Double Layer DVD+R 2.4x 8.5Gb, Reorder 43459, [DVD+R-DL:MKM-001-000].
Записан DVD-фильм, объем записи 8092 Мб. Скорость записи 2.4х, booktype установлен как DVD-ROM.
1. Чтение на самом Benq 822.
468x342, 9,2Kb - 468x342, 9,2Kb
2. Чтение на LG 4120B.
467x343, 9,3Kb - 467x343, 9,3Kb
3. Disk Quality Test в Nero CD-Speed 3.42 (PI/PIF/jitter) на Benq 822, скорость 6х (CAV).
469x419, 8,0Kb - 469x419, 8,0Kb
DVD-плеер Onkyo 501 воспроизвел диск без каких-либо проблем.
К сообщению приложены файлы: 1.png, 468x342, 9Кb, 2.png, 467x343, 9Кb, 3.png, 469x419, 8Кb
70. GeoN, 20.10.2004 00:12
Пара тестов этого DL-диска с KProbe/Lite-On 401@411, скорости чтения:
1. 2х CLV
2. 8x CAV.
Можно сравнить с тем, что получилось на Nec 2500.
Dual layer burning!, #30 (http://forum.ixbt.com/topic.cgi?id=31:18374:30#30)
К сообщению приложены файлы: 1.png, 498x618, 10Кb, 2.png, 572x672, 12Кb
71. GeoN, 23.10.2004 15:24
Сравнительные тесты DL-записи на восьми разных дисководах.
http://kimya95.storageinfo.co.kr/media/p24dl/double_…st_by_kimya95.htm
Участвовали:
Samsung TS-H552B
LG GSA-4120B, GSA-4160B
LITE-ON SOHW-832S, SOHW-1633S
NEC ND-3500A
NU Tech DDW-163
Pioneer DVR-108
Обзор на корейском, но по таблицам и скриншотам вобщем-то все понятно.
Лучшие результаты получились у NEC, LG и Pioneer.
72. @Slavik@, 25.10.2004 15:57
извини может вопрос не по теме но можно ли в Асусе 1604 менять битсетингс в DVDinfoPro? и второе где взять ету прогу - на официальном сайте даунлоад без кредитки не предусмотрен - только покупать надо....
73. Igor I, 25.10.2004 17:34
@Slavik@
Ты плохо смотрел - на официальном сайте есть ссылка http://forums.speedlabs.org/index.php/topic,696.0.html
74. GeoN, 25.10.2004 23:08
@Slavik@
Нет, ни в DVDinfoPro, ни где-либо еще. Вопрос надо ставить иначе: поддерживает ли Асус 1604 битсетинг? Ответ: для SL дисков не поддерживает, для DL дисков поддерживает, автоматически.
75. @Slavik@, 26.10.2004 09:35
Да я знаю что для DL поддерживает, а для SL.... жаль.
А вопрос задал не корректно...
Добавление от 26.10.2004 10:47:
Igor I
Спасибо за ссылку!!! недосмотрел наверно...
76. abgm, 28.10.2004 07:14
Sony upgrades its 710 series to 12x DVD-R and 4x DVD+R DL via firmware update (http://www.cdfreaks.com/news/10784)
Great news for those of us which already own a Sony DRU/DRX 710 A/UL and want that the drive becomes faster in writing DVD-R and DVD+R DL. Sony published a new firmware that upgrades the drive to 12x speed for DVD-R and 4x speed for DVD+R DL writing.
77. GeoN, 06.01.2005 13:56
Verbatim анонсировал диски 8x-speed DVD+R Double Layer:
http://www.verbatim.com/news/news_detail.cfm?news_id…-8A9E9C396F547E9D
Поставки образцов производителям дисководов (для тестов) начнутся в ближайшее время. Начало продаж намечено на 3-й квартал 2005 г.
Одновременно анонсированы диски 4x DVD-R Dual Layer:
http://www.verbatim.com/news/news_detail.cfm?news_id…-852E0B261F8F5076
Поставки инженерных образцов производителям дисководов уже начались. Доступность дисков в продаже обещана в течение 1-го квартала этого года.
78. MYury, 16.01.2005 01:29
А никто из благородных донов не подскажет ссылку на более-менее свежий обзор, позволяющий судить про надёжность чтения DVD+R9 дисков в стационарных плеерах, желательно со статистикой в духе "записано писалкой ХХХ с прошивкой YY - читаеться в ZZ процентах проигрывателей" (грубо говоря, можно детальней)? Помниться, полгода назад ситуация была не слишком радужная. Как с этим сейчас?
79. Molchun, 16.01.2005 22:55
Booktype надо перед записью выставлять? Я выставил после записи в dvdinfopro - болванка не видна. Можно ее спасти?
80. vlad001, 17.01.2005 22:52
Molchun
Booktype надо перед записью выставлять? точно.
болванка не видна где не видна? Резак всё равно должен видеть.
81. GeoN, 17.01.2005 23:02
Molchun
Разумеется. На однократные болванки booktype записывается в первой сессии. Никаких шансов изменить что-либо после этого.
82. Olgerdus, 16.02.2005 05:39
Уже полгода продаются двухслойные DVD+R, а цена них ниже 8-9$ не опускается. Как 4-5 обычных дисков. Долго ли еще так будет?
83. GeoN, 16.02.2005 19:48
Olgerdus
Как 8-10 (jewel), или ~15 (шпиндель) от того же Verbatim, так точнее.
Долго. Технология оказаласть достаточно сложной, процент выхода годных невысок. В итоге массовый выход на рынок DL тайваньских производителей не состоялся.
К этой теме 22.02.2005 05:54 moderator-abgm подклеил тему "Первые двухслойные -" (автор: Disclaimer)
85. Disclaimer, 21.02.2005 16:54
Компания Mitsubishi Kagaku Media (Verbatim) сообщила о разработке первых в мире 8,5 Гб двухслойных односторонних дисков DVD-R media, которые поступят в продажу весной текущего года.
Информация на диски может быть записана при помощи DVD-R приводов, поддерживающих технологию записи на двухслойные диски. Новинка совместима со всеми существующими стандартами для воспроизведения в DVD видеоплеерах и DVD-приводах для ПК.
Для производства односторонних двухслойных дисков компания разработала органический пигмент, основанный на уже существующем "DYN-AZO", который наносится на каждый из двух слоев. Кроме того, используется технология контроля деформации диска, что позволяет достичь высокой стабильности при записи информации и последующем воспроизведении.
И хотя двухслойные DVD-R media еще не признаются официально DVD Форумом, в компании уверены, что новые стандарты будут приняты и утверждены на официальном уровне еще до начала продаж. Стоимость дисков будет порядка $15.
86. MickeMM, 21.02.2005 17:25
Disclaimer
... хотя двухслойные DVD-R media еще не признаются официально DVD Форумом...
Всё это ерунда, Plextor PX-716A на DVD-R DL писать умеет .
87. Disclaimer, 21.02.2005 17:43
MickeMM
Не ерунда
Официально еще нету, но почти все новые приводы уже умеют их писать, вот такой вот парадокс
88. -=SpY2000=-, 22.02.2005 03:17
Disclaimer
а болванок по нормальной цене до сих пор нету
89. LNJ, 22.02.2005 04:17
речь идет о dvd-r или dvd+r
насколько я знаю все выпускаемые приводы поддерживают dvd+r DL
90. DenisN, 22.02.2005 17:03
Я вот только что заметил, что мой Samsung H552U может писать DVD+9 [MKM 001] со скоростью 6x
Или это я что-то перепутал? :/
91. DenisN, 23.02.2005 17:57
Походу действительно пишет 6х
http://kenny.storageinfo.co.kr/review/TS-H552B_US03/
92. vlad001, 28.02.2005 00:13
DenisN
А что много дисков записал?
93. DenisN, 28.02.2005 20:02
Ниодного - а что? =]
94. vlad001, 03.03.2005 20:59
DenisN
А то что фича то не востребовательна.
95. hvb, 20.06.2005 10:46
Кто нибудь сталкивался со следующей проблемой.
На диск Verbatim double layer DVD+R программой DVD-Decryptor ver.3.1.9.0 был записан образ фильма. Диск DVD-Decryptorом определился нормально, никаких ошибок или предупреждений в процессе записи не было. Recorder Pioneer DVR-109. По окончании записи ,соответственно, было сообщение, что запись успешно завершена.
Записанный диск не определяется операционной системой компьютера, на котором стоит писалка, вообще не виден на читающем DVD-R, но, если загрузить программу Nero Burning ROM (ver. 6.6.0.1), то работает кнопка «продолжить мультисессионный диск», при нажатии которой видна информация о записанной сессии
Далее после нажатия ОК для загрузки этой сессии появляется сообщение: «the selected track uses a different file system (UDF/ ISO 9660) from the document type (ISO 9660) you have selected. Do you want NERO to change the document type for you?»
Если согласиться с предложенным, то NERO читает записанную сессию. (Содержимое соответствкет тому, что должно быть записано).
Стоит ли пытаться закрыть далее этот диск с помощью NERO? Или возможен другой выход?
96. AlexXpert, 20.06.2005 12:25
hvb
у меня аналогичная фигня была с ДВД записанными пофайлово через Неро (6.6.х.х)
Писал TDK DVD-R и Verbatim DVD+R
Причем, эта Нера не могла их закрыть...
Откатился на 6.3.х.х и закрыл - нормально читаться стали (на компе, стационары не проверял).
У меня Pioneer-106D
97. hvb, 20.06.2005 13:11
AlexXpert:
В моем случае версия Decryptora, похоже, глючно работает с двуслойными дисками. Вопрос в том, можно ли после него NERой закрыть этот диск?
98. DAE2000, 23.06.2005 16:36
Как все таки происходит запись на двухслойные диски? Сначала записывается целиком один слой, потом второй, или же идет чередование 1-2-1-2... И если запись идет по первому варианту, то где закачивается запись первого слоя?
99. Accent, 23.06.2005 16:55
DAE2000
Запись первого слоя закачивается на внешнем краю диска
